Observer jchou.1992
How can Ultrascal+100G Ethernet IP connect to AXI bus?
Hello:
 I'm using ZU17EG for my design. I used Vivado Block Gen to generate "Zynq" and" Ultrascale+100G Ethernet subsystem" in my design.
Then I run "Block & Connection Automation",  only rest & clock signals are connected. All data & control signals are floating. Not interconnection to Zynq. How can I connect them?  Which IP should I add?
BTW, Does Xilinx have reference design such as document, schematics, demo program regarding this?
Jimmy
Re: How can Ultrascal+100G Ethernet IP connect to AXI bus?
Hi @jchou.1992
Ultrascal+100G Ethernet IP interface is LBUS interface not axi interface.
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
Participant johnmaclellan
Is there any code or ref design for interfacing the 100G lbus to AXIS?  Thx
