How to assign RGMII pins in zu11eg?
Hi everyone
    what's kind of  port  does the RGMII port can be use in ultrascale+ fpga?
    When I use Tri_mode_ethernet_mac ip with Rgmii in zu11eg, I don't know how to set them.
	output					o_poe_rstn,
	output  [GE_NUM - 1 	: 0]		o_phy_resetn,
	output 	[GE_NUM*4 - 1 	: 0]  	        o_rgmii_txd,
	output  [GE_NUM - 1 	: 0]          	o_rgmii_tx_ctl,
	output  [GE_NUM - 1 	: 0]          	o_rgmii_txc,
	input  	[GE_NUM*4 - 1 	: 0]		i_rgmii_rxd,
	input  	[GE_NUM - 1 	: 0]          	i_rgmii_rx_ctl,
	input   [GE_NUM - 1 	: 0]          	i_rgmii_rxc,
	inout   [GE_NUM - 1 	: 0]            io_phy_mdio,
	output  [GE_NUM - 1 	: 0]            o_phy_mdc
Does t/rxc must set DBC port and QBC port?
Does t/rxd must set  normal HP port ?
what 's the relationship between these port ?
when I set 8 tri_mode_ethernet_mac in my project,I got this result.
what's that mean?
Tags (3)
@xumoxiao,
you have not pin-mapped your RGMII ports to the FPGA pins.
Refer to the ultrascale data sheet as to which FPGA pins you can connect them. You cannot connect them to any IO port. That is why you are seeing the 1st error message.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
@dpaul24
Thanks for your reply.
Can you describe it in more detail?
@xumoxiao,
I might have misunderstood your initial question. It seems you have connected the rgmii ports to the FPGA pins.
Now please re-read the Vivado generated messages. Your *txc now are connected to pins D19 and T15 which cannot be obeyed due to the placement of *_delay_rgmii module/s.
You need to look in to your placed design. Find out the pins suitable to be connected near to the placed *_delay_rgmii module/s and connect the *txc to them.
@dpaul24.
I think I found the key. In Pg051, I found that.
So the red box in the illustration below cannot be used, only the remaining DBC, QBC, GC pins can be used
I ca n’t understand the phrase "RX Data/Control pins or any input pin which needs to be routed through IDELAY cannot be placed at BITSLICE below TXC".
Because the pin assignments in the picture below are correct
But TXC is above RXCTL!!!
How to explain this
Please help!
