How to switch between 100M and 1G in Tri mode ethernet mac
Hi,everyone
I explain my understanding firstly.
The PHY chip can switch to 100M or 1G correctly after Auto-Negotiation.
Then we can read the PHY status through MDIO&MDC interface to learn which link speed is in Physical Layer.
Next,based on the PHY link speed status,we can config Tri mode ethernet mac speed by value [31:30] in MAC Speed Configuration Word (0x410).
Is my understanding correct for switching between 100M and 1G in Tri mode ethernet mac?
Scholar dpaul24
Re: How to switch between 100M and 1G in Tri mode ethernet mac
@topxuxiang8,
Yes.
FPGA enthusiast!
All PMs will be ignored
Yes that is the documented way to do the speed change, see PG051 page 254 "Configuring the Ethernet MAC to the Correct Speed"
--Kim
Thanks a lot for your reply
thank you
Hi @topxuxiang8,
If your question has been answered, could you please mark the relevant post as "Accepted Solution"? So it will benefit other forum users.
Thank you!
"Don't forget to reply, kudo and accept as solution."
