Observer aobeid
IBERT / Virtex-5 / Invalid line rate & REFCLK
Hi all,
I'm facing a problem when using IBERT on XC5VFX70T-2-FF665.
The line rate, after programming the FPGA, doesn't match the selected one using the wizard in Core Generator.
Furthermore, the *.xco file includes the following statements that don't match as well:
  • CSET x0y2_gtx_dual_rx_line_rate=3.125
  • CSET x0y2_gtx_dual_rx_refclk_val=156.25
In what follows, snapshots are given that illustrates the IBERT settings:
Moreover, when selecting Near-End PCS the line rate reaches 7.812 Gbps which exceeds the limit of 6.5.
Thanks in advance for any feedback.
Tags (4)
Re: IBERT / Virtex-5 / Invalid line rate & REFCLK
Which version of ISE tool you are using?
can you check the following attributes in IBERT GUI?
PLL_DIVSEL_FB
PLL_DIVSEL_REF
DIV
I am referring to the Equation 5-1 in ug198. By using the equation you should be able to find the expected line rate.
f(PLL Clock) calculated from this equation is half of the line rate.
Observer aobeid
Thanks very much for your reply.
  • Version 14.7
  • PLL_DIVSEL_FB = 5 (Radix: UCF)
  • PLL_DIVSEL_REF = 2 (Radix: UCF)
  • DIV = 4 since OVERSAMPLE_MODE = 0 (Radix: Bin) & INTDATAWIDTH = 0 (Radix: Bin)
According to equation 5-1, f(PLL Clock) = 2.5 Ghz => Line rate should be 5 Gbps.
To be accurate, can you check the attributes on hardware when you load IBERT bit stream. That could confirm if the observations are related to some tool issue.
Observer aobeid
The values are taken directly from ChipScope after loading the bit stream.
