Implementation of tri mode ethernet Mac with gig eth pcs pma
I am trying to implement 1Gsps Ethernet, for that i want to connect exernal PHY device using SGMII mode.
To implement above i have taken Two IP core
1. tri_mode_eth_mac_v5_5(evaluate the core)
2. gig_eth_pcs_pma_v11_5
and i made all the inter connections between them and synthesis also fine now the problem is when i programed the KC705 the link is not establishing.
my board is KC705, Xilinx version is 14.4.
is there any thing that i have missed or i need to be done.
Praveen g
Re: Implementation of tri mode ethernet Mac with gig eth pcs pma
Have you enabled Autonegotiation at both ends.
Is the link struct at Auntonegotiation or synchronization step.
Try the suggestions mentioned in the debugging section of PG047
Satish
You can use the reference design attached to the AR or compare your design with it.
http://www.xilinx.com/support/answers/46384.htm
Satish
Thanks for your reply, implemented all the points as per your attached link but it is the same the link is not establishing.
Is there any other points that i am missing please guide me.
Praveen G.
Satish
