Implementing the 7 Series FPGAs Transceivers Wizard example design in 2014.1
I am attempting to implement the 7 Series FPGAs Transceivers Wizard v3.2 example design in Vivado 2014.1 so that I can try running it in hardware using an Artix-7 AC701 Evaluation Kit. According to the "Implementing Using the Vivado Design Tools" section of chapter 6 in PG168:
"After wrapper generation is complete, the results can be tested in hardware. The provided example design incorporates the wrapper and additional blocks allowing the wrapper to be driven and monitored in hardware. The generated output also includes several scripts to assist in running the software.
From the command prompt, navigate to the project directory and type the following:
For Windows:
    > cd xaui_wrapper\implement
    > implement.bat
Note: Substitute Component Name string for xaui_wrapper.
These commands execute a script that synthesizes, builds, maps, places, and routes the example design and produces a bitmap file. The resulting files are placed in the implement/results directory."
Unfortunately, I cannot find implement.bat or any other generated batch file or TCL script that looks like it would do the job. Am I missing something here? Has this functionality been removed from the example design?
Thanks in advance for your help!
Best regards,
Dave
Community Manager
Community Manager
Hi Dave,
The implement.bat file is not generated in vivado.
You can use the below tcl command to generate the .tcl file in the TCL console of the example design project-
launch_runs synth_1 impl_1 -scripts_only
This will generate two tcl files- one for synthesis (in <core_name>_example.runs\synth_1) and one for implementation (in in <core_name>_example.runs\impl_1)
Krishna
Community Manager
Community Manager
Hi Dave,
Krishna
