powell007
Is it possible to use SFP+ transceiver for any protocols for GTX transceivers?
  I want to test SFP+ module. Is it possible to use SFP+ transceiver for any protocols for GTX transceivers?
smarell
Community Manager
Community Manager
Yes you can use it. SFP is just a connector, you can use it with all the supported protocols with GTX provided the SFP can support the line rate that you are targeting.
Krishna
smarell
Community Manager
Community Manager
Krishna
powell007
