JES204B on Spartan 6
Does anyone know if there is IP for a JES204B interface available for the Spartan 6 devices?
Re: JES204B on Spartan 6
Hi Vanitha,
Thanks for reply, I'll have a look at the link you provided.
Robert
JESD204B IP is not available for Spartan6 devices.
It is available only for virtex6 ,7 series and Ultrascale devices.
Satish
Xilinx proovided JESD Ip core do  not support Spartan-6, but you may check for third party IPs, please visit below link and contact the vendor.
http://www.avateq.com/news/8/Avateq-introduces-new-IP-cores-for-JESD204-interface-on-Spartan-6-and-NXP-ADCs-and-DACs
Hope this helps
Vanitha
Hi Vanitha,
Robert
I would recommend to try the latest device for JESD204b design. For low cost solution you can use Artix-7 device
Here is the link for JESD204 High Speed Interface solutions and related documentation
http://www.xilinx.com/products/technology/high-speed-serial/jesd204-high-speed-interface.html
Thanks and Regards
Balkrishan
