JESD Core and TLAST
Does the AXI Core streaming slave in the JESD204B core use TLAST at all? I found no reference to it in the documentation.  What should TLAST be set to?
Tags (2)
Re: JESD Core and TLAST
The TX core stream interface uses only tready and tdata signals and remaining signals can be left unconnected as there are no top level ports
Refer example design generated with the core to get familiar with how the data interface is driven.
Satish
Satish
