Visitor shynasd
JESD sync issue
I am using Xilinx JESD transmitter IP core 7.1 along with AD9164 DAC receiver. Once in while it is observed that even after sync de-assertion JESD transmitter is transmitting K28.5 character.
Thanks and regards,
Shyna
Re: JESD sync issue
If sync is deasserted, and you see K characters (bcbcbcbc) being sent, this could trigger a resync event.  After this data is seen on the link, does the link lose synch and resync?
Visitor shynasd
Re: JESD sync issue
Once the K characters (bcbcbcbc) are being received, sync~ signal is de-asserted(logic high) and remains in that state. The link will not resync unless and until it is forced to do so.
