JESD tx_core_clk_out
Can I use JESD core_clk_out as input to MMCM and generate clocks for internal logic.
Yogitha
Re: JESD tx_core_clk_out
I checked it for JESD Tx core. tx_core_clk_out is output from GT reference clock input buffer. You can use it to drive an MMCM and generate clocks for fabric logic.tx_core_clk_out.JPG
Participant bitstreamer
I'm not sure this holds up to latest versions? I think you're supposed to use IBUFDS_GTE* to drive the JESD PHY and use the parallel output (with optional divider) to drive the fabric through an HCLK row.
