pranaychandram
LUT usage for TRIMAC core
I would like to know the LUT usage and other FPGA resource usage
when Soft IP Tri MAC core is implemented in Virtex5 LXT device.
I couldn't find this information on the xilinx site, if any one has it, I would
appreciate if you could share it.
-Pranay.
kotir
Trimode mac version 4.5 will support virtex-5 devices.
The below document will provide you the utilization nimbers for softmac on V5 devices.
http://www.xilinx.com/support/documentation/ip_documentation/tri_mode_eth_mac_ds297.pdf
Here is the userguide for this ip.
http://www.xilinx.com/support/documentation/ip_documentation/tri_mode_eth_mac_ug138.pdf
KR
pranaychandram
Thanks Kotir
