brandnj20fiber
LWIP UDP Loopback with Ultrascale and 88E1512
We have a PCB with an Ultrascale connected to a 88E1512 and transformer through the MIO pins. I would like to run a loopback test using LWIP UDP without going through a router. Is this even possible if I were to connect the transformer TX to RX pins?
I really have no experience with Ethernet or the LWIP c code. Just need to know if this is even viable before I try it.
