LWIP echo server will not send more than 1500 bytes over TCP
I changed the ip_frag_max_mtu to 2000.  This was the only variable with a value of 1500 in the BSP.  I checked over wireshark and the lwip echo server will not send any TCP packets larger than 1500.  How will I change this?
I'm using Zynq 7000 and as per UG585 jumbo frames are not supported.  1500 byte payloads are the limit.
Hi @jcwill585 ,
Which IP are you using? Have you enabled Jumbo frames?
Please note, if using zynq PS GEM, jumbo frames are not supported, so you won't be able to send over 1500 bytes.
"Don't forget to reply, kudo and accept as solution."
I'm using LWIP 211 version 1.0.  Jumbo frames are enabled.  I'm not sure if I'm using GEM.
