david.mcdaniel
LogiCORE IP Tri-Mode Ethernet MAC v8.2 example design
I recently purchased the TEMAC core to implement an RGMII Ethernet interface on a Kintex-7.  The product guide refers to an example design, but I when I generate the core (targeted to a part or to a board), I cannot find any example design files being generated.
How do I get/find these files?
Dave
yenigal
Hi Dave,
After generating the core,you need to right click on the xci file  which will show you the option of example design as shown in the below snapshot.
Satish
