Visitor ilias
Low bandwidth in xapp1305 fror zcu102
Hi All,
I am testing 10Gb Ethernet  using binaries from xapp1305 ( Version: 1.2 from  19APR2018 )
My setup is
zcu102 FPGA with SFP+ adapter from Avago  connected to Intel 10Gb card on desktop Linux system.
I am running iperf3  on FPGA side
iperf3 -c 192.168.1.1 -b10G -w32M -t=99999
and on PC side
iperf3 -s -i1
I am getting very low bandwidth of about 200Mb ( mega bit! not byte)
What is a really interesting , if i am adding -Z flag to iperf, I am getting a pretty good  bandwidth of about 1.8Gb ( giga bit)
It is very unusual that zero copy can make a x8 impact on network bandwidth.
Looking into wireshark capture, I see that in case of normal( non zero copy) session, TCP packet size is small( ~4K) which explains low bandwidth.
I will really appreciate a hint here, as moving our app to zero copy seems not simple
( actually, I am not sure how to do it from Linux user mode )
Ilia
Tags (2)
Observer jbeck695
Re: Low bandwidth in xapp1305 fror zcu102
I'm curious if you ever figured out a solution here. It took me a while to finally get it working but I just got same connection you mention above working yesterday. My first performance test was to try iperf3 that was included in xapp1305 but iperf3 on zcu board was missing a library so I just ran a simple scp of an 8gb file. Throughput was awful (12M/sec) but I haven't really dug much as of yet. I'm doing that now & came across your post. I figured I'd reach out to see if you discovered any optimizations.
Thx,
Joe
Visitor ilias
It was some time ago, but I remember that upfarding xapp1305 reference design to v.1.3 ( https://www.xilinx.com/support/documentation/application_notes/xapp1305-ps-pl-based-ethernet-solution.pdf ) had a great impactr on the bandwidth.
Also, you may want to configure mtu to somethink like 9000
Observer ammadali90
I am looking for xapp1305 design for vivado 2017.3  (Version: 1.2 from 19APR2018). The current version of xapp1305 is for vivado 2018.
Unfortunately, I didn't find that design. Do some one know where can I find that design version?
Best Regards,
Ali
Re: xapp1305 fror zcu102
Hi @ammadali90 ,
Our Community Help has a tip that might help you : Tip: If the message is older than 6-12 months, please post a new message rather than adding to the existing thread. Your inquiry will have a better chance of being picked up by an expert if it is a new topic.
I would suggest you create a new topic on the appropriate board.
"Don't forget to reply, kudo and accept as solution."
