srojas
LwIP warning in tcp.c "comparison is always true" in 2020.1
I recentrly switched from using the lwip202_v1_1 (2018.3) with a ZYNQ to use the lwip211_v1_2 (2020.1) with an Ultrascale MPSoC. When compiling the platform project I see the following warning:
comparison is always true due to limited range of data type [-Wtype-limits] tcp.c /platform/psu_cortexa53_0/standalone_domain/bsp/psu_cortexa53_0/libsrc/lwip211_v1_2/src/lwip-2.1.1/src/core line 992 C/C++ Problem
It involves these two lines (992 and 996) in tcp.c
This is because tcpwnd_size_t is defined as u16_t in tcpbase.h and TCP_WND_MAX(pcb) as TCP_WND in tcp.h
tcpbase.h
tcp.h
Since I previosly had configured the WND size in BSP (lwipopts.h) as
#define TCP_WND 65535
I was wondering if I should ignore this warning or if I should activate LWIP_WND_SCALE to use u32_t for tcpwnd_size_t .
Does anyone have an idea?
Tags (2)
nanz
Hi @srojas ,
I believe this can be safely ignored! Do you see any unexpected behaviour caused by this warning?
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
nanz
Hi @srojas ,
srojas
Hi @nanz
Thank you for the response.
Until now I have not seen any unexpected behavior. For now, I'm not been transmitting too much data.
Kind Regards
