MGT / Aurora
Hi all,
I am trying to use a Aurora Core and MGT transceiver to get high Speed serial transmission signal out.
I have run into several problems..
One problem is getting the Aurora Core simulated...
I generated a core using the core generator with the following settings. Streaming, Simplex -Both directions.
I tried to simulate the design using the given tb and the do scripts. The clocks are toggling..but there is not data being transferred.. I tried several versions of the aurora 2.4, 2.6, 2.7, 2.7.1.. Still the same issue.. Do_CC is also not asserted. so idle signals are not being sent... Is there something I am missing...
Also I need to send the high speed signal out to to RF unit...
So there is no initialization signals being sent back..  And tx_d_ready signal from the receiver.
The initialization can be probabaly set by the sender side.. but how does the tx_d_ready signal assrted from the GT_Aurora primitve.
FPGA Board - Xupv2p
FPGA - XC2VP30
My setup is ISE 9.1i Sp3.
Cheers
Shakith
Re: MGT / Aurora
I am not sure which simulation tool you are using.
MXE and ISIM doesn't support MGT simluation.
You have to ust SE or PE edition with xilinx smart modules
