venugopal.kulkarni
Maximum data rate possible for Ethernet implementation in ZCU 106
I want to know in ZCU106 reference board:
1) Maximum possible data rate that can be achieved by implementing Ethernet . (PS and PL section both).
2) How many I/O Banks (or number of pins) required for Both (PS/PL).
3) If I go for HDMI, What can be maximum data rate?
4) Is there any special port or I/O provided for HDMI or we have to use the common I/O bank (please mention the bank number and number of pins required)?
Thanks in advance.
nanz
Hi @venugopal.kulkarni ,
1) Our application note XAPP1305 has the performance data documented as following:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841752/ZynqMP+Ethernet+Performance+2017.3
This is based on ZCU102 and will be very similar to what you can get on ZCU106.
2) Please check XAPP1305 example design to get this info.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841830/PS+and+PL+based+Ethernet+in+Zynq+MPSoC
3) & 4) For HDMI related questions, please post your questions on Video and Audio board below:
https://forums.xilinx.com/t5/Video-and-Audio/bd-p/DSPTOOL
"Don't forget to reply, kudo and accept as solution."
nanz
