Visitor codesmagic
Multiple Ethernet Transceivers
I want to make a frame from 5x 10/100Base Ethernet transceivers and send it through a Gigabit Ethernet.
Is it possible to implement Soft MACs for 10/100Base Ethernet transceivers and rout its signals to the PHY IC through usual ports of FPGA or I should use ISERDES/OSERDES Transceivers?
Thank you in advance.
Scholar drjohnsmith
Re: Multiple Ethernet Transceivers
Ok, I see your problem  now, its not just Ethernet.
As a point of referance, a managed switch, you can do the sort of thing with ethernet you want to do.
If you want to work with 4 USB as well as CAN and Ethernet, sounds like you want a Processor not an FPGA .
If you do an FPGA, it will be a processor inside, maybe doen in many different fighting state machines,
The sort of thing they do for trading floor processors,
10/100 Ethernet, is ging to come into the FPGA on an external PHY,
  such as this
https://www.microchip.com/wwwproducts/en/KSZ8081
most ( all ) of the PHYs talk using the RMII interface spec to the FPGA / Processor,
    which is a 50 Mhz interface, no need for highspeed SreDes on th FPGA,
https://en.wikipedia.org/wiki/Media-independent_interface#Reduced_media-independent_interface
You would then have your MAC in the FPGA code, one for each PHY.
something like this
https://www.xilinx.com/products/intellectual-property/axi_ethernetlite.html
Note if your 10/100 data rate is low, there are SPI <=> Ethernet chips.
  such as these
https://www.microchip.com/wwwproducts/en/en022889
then you would just have an SPI interface between the FPGA and th echip, the MAC and PHY is now done for you
for the Gbit ethernet , there are many optoins, from using the built in , to off chip MAC and or PHY
https://www.xilinx.com/products/technology/ethernet.html
Scholar drjohnsmith
can you post a picture of the idea ?
Sounds like you have 5 slow ethernet ports, coming into an FPGA,
and you want to send that out on one fats Ethernet port
Have you considered just using an off the shelf giga bit switch,
https://www.digikey.co.uk/product-detail/en/tripp-lite/NG5P/TL1546-ND/6204967
Visitor codesmagic
Thanks for reply.
As its clear acording to the picture picture I can't use Ethernet Switch for whole designe.
I don't have access to the Low Rate configuration, then I can't change their destination IP to the same one and use Eth. Switch and just connect one instead of five to the FPGA.
Scholar drjohnsmith
  such as this
something like this
  such as these
Visitor codesmagic
something like this
Thanks for reply.
I don't want use processor for ethernet tranceivers. I just want to buffer incoming data and insert it in to the frame.
Do I have to use DMA to build the frame?
Otherwise I don't need to use "AXI" Ethernet, as I think.
Scholar drjohnsmith
Are you going to write your own MAC for the PHY in the  FPGA
  in that case, you can do what you want,
    if its an off the shelf MAC, then its going to be AXI
Info on what the MAC does
https://en.wikipedia.org/wiki/Medium_access_control
Re DMA. is just a way to move data from one memory area to another,
     it is not a requirment of Ethernet just one of many methods.
You can build wthernet frames using state machines.
Visitor codesmagic
Thanks for reply.
I didn't know that we don't have direct access to the internal FIFO of IPs like Tri Mode MAC Ethernet, AXI Ethernet.
May I ask you to suggest me an architecture in a picture to build the frame without using processor? (Please just consider 250 additional bits instead of USB and CAN medias)
Scholar drjohnsmith
sorry, cant add much more without doing the design.
