Mutilple Aurora 64b/66b problem
I want to communicate between 2 KC705 and a VCU118 Board using a QSFP to 4 SFP Cable, with Aruora 64b/66b ip core.
The VCU118 project have 2 Aurora 64b/66b ip cores, 1 with shared logic in the core as master mode and 1 with in  example design as slave mode, they were connected same as the ip document(PG074) shows.
Then I use a vio core in KC705 to monitor link status.
Sometimes it works good ,after downloading the bit, channel_up goes high and the data transfers perfectly.
But sometimes after I download the bit, the KC705 attatched to the MASTER mode Aurora 64b/66b in the VCU118's channel_up goes high, while the KC705 attatched to the SLAVE mode 's channel_up goes to unstable status ,shown blow with pic.
Hello @zhu19940520
  1. Are those Aurora 64B/66B IP Duplex or Simplex IP ?
  2. I suspected it is reset sequence timing problem.
    (a) Could you try to power on VCU118 board first , before powering up KC705 (B) ?
    (b) Did you try to re-initialize KC705 (B) ? Is the issue still persist ?
3. When you saw this issue , is the lane_up also low ? are you seeing hard_err=1, soft_err=1 ?
Leo
After reducing lane speed to 6.25Gbps ,  the problem is *almost solved
(When power on VCU118 first, both KC705 always initialize sucessfully. But powering on KC705(B) first sometimes still goes to the problem.)
1 They are both duplex IPs.
2 Powering on VCU118 first will bing a higher success rate, but also fail sometimes.
I've tried to re-initialize all the boards ,but it didn't work;
3 Hard_err asserted. But I didn't monitor lane_up and soft_err.
Hello @zhu19940520
So, reducing the line rate helps.....
  1. Could you please see if lane_up=0 in 7-series Aurora IP?
  2. Aurora 64B66B for 7-series has DFE as a default EQ setting.
    Which is may not suitable for channel with low insertion-loss. ( You are using optical module, with very close distance to the Kintex-7 FPGA). For 7-series Aurora IP, Could you modify the EQ setting to LPM ?
Thanks & regards
Leo
