Network access to linux booted on ZCU102
I am able to load petalinux onto zynq zcu102. Can anyone point me to the procedure to enable network access through the ethernet port?
Hi @suhas99hv ,
Please check XAPP1305 for reference:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841830/PS+and+PL+based+Ethernet+in+Zynq+MPSoC
"Don't forget to reply, kudo and accept as solution."
Thanks @nanz
But can you please tell me if setting ip address in ifconfig, setting gateway default and DNS server directly in the terminal would work or not?
Hi @suhas99hv ,
When booting to kernel, you can check if Ethernet driver has been correctly probed and then in ifconfig -a , you are able to see all available interfaces. You can use ifconfig to set ip address and gateway etc. And ifconfig eth0 down and up to bring up the ethernet interface.
When I connect the ethernet cable I get the following in my console during bootup
** 69 printk messages dropped ** [ 18.653876] macb ff0e0000.ethernet eth0: DMA bus error: HRESP not OK
Is this because the ethernet port is not configured?
Hi @suhas99hv
Are you using the custom design HDF or seeing the issue with zcu102 BSP? Please do let us know the petalinux version being used?
Best Regards
Shabbir
I'm using petalinux version 2018.3 and zcu102 BSP version 2018.3. I created the hdf file following UG1209(v2018.2).
Hi @suhas99hv
Thanks for the details. Did you enable any isolation configurations while creating the design?
Best Regards
Shabbir
Yes I have enabled isolation configuration as mentioned in UG1209.
