jeevanreddymandali
No REFCLKPWRDNB in my GTX wrapper file
Guys, I had the physical DRC error. I was asked to follow AR#33473. But I donot have REFCLKPWRDNB  in my wrapper file. What to do now? In my design I am using two independent tiles of X0Y3(only X0Y3).
jeevanreddymandali
Tags (3)
venkata
It looks like you are expecting similar terminology between GT and Aurora. Actually they are different.
With Aurora, POWERDOWN_IN port connects to both TXPOWERDOWN, RXPOWERDOWN.
In general, REFCLKPWRDNB is not brought to user level. It will be connected to VCC as shown below.
.REFCLKPWRDNB (tied_to_vcc_i),
Please refer to *_tile.v file to bring this port to top level and do the necessary connections.
This means REFCLK is always enabled.
smarell
Community Manager
Community Manager
Which device are you targeting?
As per the answer record, REFCLKPWRDNB needs to be tied to 1 when you power down the transceiver by connecting TXPOWERDOWN[1:0] and RXPOWERDOWN{1:0] to "11" to save power.
If you don't power down the unused transceiver then you need not tie REFCLKPWRDNB to 1.
jeevanreddymandali
I am targeting Virtex-5 xc5vfx100t-1ff1136. Okay brother, if thats the case, but where is my REFCLKPWRDNB signal? After seeing you r answer now I come to know that I donot even have TXPOWERDOWN, RXPOWERDOWN signals(ports). I only have a POWERDOWN_IN port. OMG!
jeevanreddymandali
smarell
Community Manager
Community Manager
I've generated a GTX core for the specified design and could see the ports- TXPOWERDOWN0 & RXPOWERDOWN0 in the _tile.v file. I could also see REFCLKPWRDNB  port.
jeevanreddymandali
which version are you using? I am using 12.4 and aurora v6.1. Even now I generated a new file, I donot have them.
jeevanreddymandali
smarell
Community Manager
Community Manager
I'm using 14.6 version of tools. I have generated Aurora 8b/10b v5.3 core and could see these ports in GTX_DUAL instantiation.
Can you please share aurora*_tile.v (or vhd) file?
venkata
venkata
one other note...please post Aurora related queries in connectivity board.
jeevanreddymandali
Thanks for your time really smarell! Here is my _tile.vhd file. Actually I have no one to teach me. I am doing every step basedon net and pdfs. Thats why I may be doing such silly mistakes.
jeevanreddymandali
jeevanreddymandali
sorry venkata from next time I will follow this rule. Thanks. I attached my _tile.vhd . Please take a look!
jeevanreddymandali
