joab1
On-board Ethernet between two Zynq Ultrascale
Hi. Is it possible to use the IP 1G/2.5G Ethernet PCS/PMA or SGMII (16.1) to establish a ethernet connection between two zynq ultrascales on the same board without external phys? I am using Pelalinux and it would be perfect if there is a way to emulate a ethernet phy in PL so the communication between the zynq ultrascales look like a regular ethernet link from the Linux OS.
Thank you for taking your time.
shabbirk
Hi @joab1
If you are using 1000base-x/sgmii SFP's at both the board sides for the testing then it's possible. We do have XAPP1305 for PL ethernet 1000base-x/sgmii here for your reference:
https://github.com/Xilinx-Wiki-Projects/ZCU102-Ethernet/tree/main/2019.2/pl_eth_1g
Shabbir
joab1
Thank you. I find it a little unclear how to implement this in my vivado design(s). Is there any vivado example project available that can be used as refecrence?
Best regards
Johan
dpaul24
@joab1 ,
This is how communication at the MAC data link layer takes place b/w two eth sub-systems:
 mac-back_end <--> Eth MAC <--> PHY <-----wired/wireless connection-------> PHY <--> Eth MAC <-->  mac-back_end
Now in your case, the PHYs are missing (you do not have to emulate the PHY). So for your design the connectivity becomes....
mac-back_end <--> Eth MAC <- mac-front_end to mac-front_end-> Eth MAC <-->  mac-back_end
This is basically the concept. The mac-front_end to mac-front_end protocol can be anything SGMII/RMII/RGMII/GMII, whatever suits yours design. You just tie the rx lines to the tx lines and vice-versa. Take care about the clocking. That's it.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
bitjockey
Technically I suppose the PCS_PMA that the RocketIO/SelectIO silicon is being configured as is still "PHY" under the hood, just without the final electrical-to-optical conversion of the usual fiber, and staying electrical instead.   You are right that any of the *MIIs will work.  SGMII and the PCS/PMA will require RocketIO (whoops, I was thinking 10G and/or 7-series products that don't do 1G SelectIO) but will have the benefit of being a pair of LVDS pairs which is a differential routed pair (x2) on the circuit board.  Any of the other *RMIIs are parallel single-ended, (though still source-synchronous chanels) which will make the circuit board a little bit more complex/congested, but can use regular GPIO and not the RocketIO silicon inside the chip.  It's a tradeoff.
Note that for SGMII/SerDes connection will likely need DC blocking capacitors in series on the diff pair for the LVDS signaling (not a big deal, but don't forget them).  It's always way harder to add them after the board is manufactured :-P.
Update https://www.xilinx.com/support/documentation/ip_documentation/gig_ethernet_pcs_pma/v16_2/pg047-gig-eth-pcs-pma.pdf seems to indicate that SelectIO in even the 7 series can be made to work in SGMII mode, just not 1000BASE-X mode, if the speed grade is right.  This confuses me because electrically both are the same 8B10B 1.25Gbps physical signaling with slight data differences only--timing and signaling speed/levels are the same.
