Visitor ngwill
PCI interrupts
I have been trying out the example VHDL for the Xilinx Initiator/Target PCI core.  Starting with the ping.vhd example, I removed all the initiator stuff to keep it simple and output a byte in BAR0 to some seven segment displays on my development board.  My linux driver works at this point, so I can read and write to that register.
Now I'm trying to use a push button as an interrupt.  Just as a crude check I used the push button to assert the interrupt signal and managed to get the driver to change the register.  Of course, I want to use interrupt acknowledgement to deassert the interrupt signal so that only one interrupt is generated for each time the push button is pressed.
I thought that I could wait for a change in PCI_CMD(0) (Interrupt acknowledge) before deasserting the interrupt and that would be it.  Is there anything obvious that I'm not doing correctly?
Nathan
Visitor ngwill
Re: PCI interrupts
I've got it working now.  I found that I shouldn't have the interrupt acknowlegement enabled in ping_cfg.vhd.
