PL 10G in u-boot v2019.1
I have an custom device referenced from ZCU102 with PL 10G SFP+ supported. Yocto with meta-layer 2019.1 from Xilinx was used.
The 10G network works in Linux, but not in u-boot. So, my question is does anybody have PL 10G driver works in U-boot?
Thank you.
Re: PL 10G in u-boot v2019.1
Hey @nvl1109,
Unfortunately there aren't any U-Boot drivers that we provide for the 10G/25G core. However, that being said, you could likely create your own without too much difficulty by referencing how the AXI Ethernet driver in U-Boot works:
https://github.com/Xilinx/u-boot-xlnx/blob/master/drivers/net/xilinx_axi_emac.c
(you could even use this as a framework)
And then comparing that against the Kernel AXI Ethernet driver:
https://github.com/Xilinx/linux-xlnx/blob/master/drivers/net/ethernet/xilinx/xilinx_axienet_main.c
In Kernel, the AXI Ethernet driver is what is used to drive:
  • AXI 1G/2.5G Ethernet Subsystem
  • AXI 10G Ethernet Subsystem
  • AXI 10G/25G Ethernet Subsystem
  • USXGMII
Clayton
Hi @nvl1109 ,
Could you share the log file on uboot run to understand what exactly are you testing?
Praveen
Hey @nvl1109,
  • USXGMII
Clayton
Thank you all for your replies.
Actually, u-boot driver for 10G now isn't in our focus. I will try to support 10G interface in u-boot when I have free time. Thank you.
