PS Ethernet Jumbo frame supported boards?
Can anyone provide a list for all boards that supports jumbo frames on the PS Ethernet?
I would be grateful
Thank you very much
Tags (4)
Hi @halkhalaf,
Zynq-7000 devices don't support jumbo frame with PS Ethernet, but you can use AXI Ethernet IP on PL side to support Jumbo frame.
Zynq MPSoC devices support jumbo frame with PS Ethernet. Boards are ZCU102, ZCU104, ZCU106 and so on.
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Hi @halkhalaf,
Thank you for the information
