Visitor vagrawal2
[Place 30-510] Unroutable Placement
I have 2 separate Aurora cores I'd like to instantiate, each containing 4 lanes and sharing one refclk.  The "master" core has 'shared logic in the core' and the "slave" core has 'Include shared logic in the example design'. I hooked it up exaclty as in Figure 3-17 in pg074, but I get the following placement error:
[Place 30-510] Unroutable Placement! A GTHE_COMMON / GTHE_CHANNEL clock component pair is not placed in a routable site pair. The GTHE_COMMON component can use the dedicated path between the GTHE_COMMON and the GTHE_CHANNEL if both are placed in the same clock region.
It might be that each IP core is trying to share a single GTHE_COMMON, which I think is not allowed.
Should both IP cores be configured for 'shared logic in the core', and if so, how should I hook up the refclk?  In what case are you supposed to follow Figure 3-17 of the Aurora User's Guide?
Teacher xilinxacct
Re: [Place 30-510] Unroutable Placement
@vagrawal2
Do any of these solutions give you any insight?
https://forums.xilinx.com/t5/7-Series-FPGAs/Unroutable-Placement/m-p/417875#M3587
https://forums.xilinx.com/t5/7-Series-FPGAs/Place-30-139-Unroutable-Placement-PicoZed-7030-SOM/m-p/713541#M18001
https://forums.xilinx.com/t5/7-Series-FPGAs/Multiple-clock-gating-Unroutable-Placement-Errors/m-p/696302#M16547
https://forums.xilinx.com/t5/Embedded-Development-Tools/Unroutable-Placement/m-p/48301#M10732
https://forums.xilinx.com/t5/Implementation/Place-30-510-Unroutable-Placement/m-p/810325#M19455
https://forums.xilinx.com/t5/Implementation/ViRTEX7-How-to-resolve-quot-Place-30-136-Unroutable-Placement/m-p/729109#M16426
https://forums.xilinx.com/t5/Implementation/Error-Place-30-124-Unroutable-Placement/m-p/688125#M14964
https://forums.xilinx.com/t5/Implementation/Place-30-140-Unroutable-placement-A-GTXE-COMMON-GTXE-CHANNEL/m-p/671542#M14228
https://forums.xilinx.com/t5/Implementation/GT-BUFGCTRL-Unroutable-Placement/m-p/264146#M5311
https://forums.xilinx.com/t5/Implementation/ERROR-Place-1158-ERROR-Place-1160-Unroutable-Placement/m-p/317017#M6137
https://forums.xilinx.com/t5/Networking-and-Connectivity/Unroutable-Placement/m-p/474076#M6082
https://forums.xilinx.com/t5/Networking-and-Connectivity/Unroutable-placement/m-p/449032#M5746
https://forums.xilinx.com/t5/Serial-Transceivers/Place-30-140-Unroutable-Placement-A-GTXE-COMMON-GTXE-CHANNEL/m-p/735730#M1858
https://forums.xilinx.com/t5/Welcome-Join/Place-30-140-Unroutable-Placement-A-GTXE-COMMON-GTXE-CHANNEL/m-p/696363#M35917
Hope that helps
If so, please mark as solution accepted. Kudos also welcomed. :-)
