Anonymous
Not applicable
Problem about rxcodeerr, with vertex6 GTH, 64b/66b encoding
Hi, I encountered a problem about recodeerr provided by vertex 6 GTH.
As we know, if a GTH link is physically disconnected(the cable is removed), we can see rxcodderr ports from the corresponding GTH lanes would become '1' or keep jumping.
In the vertex6 chips, I configured 2 GTH as 2 independent link, which connect to 2 different chips.
The quads I used are GTHE1_QUAD_X1Y1 and GTHE1_QUAD_X1Y2.
But, if I disconnected the cable of X1Y2, the rxcodeerr of X1Y1 would be seldom  '1'(kept for only 1~2 clks rarely).
I thought that that 2 links should operate independently. When X1Y2 is disconnected, the link of X1Y1 should keep its operation normally, but the recodeerr of X1Y1 shows up sometimes.
How can I solve  such a problems, or should I directly omit the recodeerr of X1Y1 in this situation?
Thank you.
Anonymous
Not applicable
Here are some further details.
The frequency of X1Y1 rxcodeerr happening is about 1 Hz.
Every time it shows up, it only keeps 1~2 clks.
At that clock, the received data pattern is also crashed, so we cannot directly omit the rxcodeerr.
It seems that the operation of X1Y1 is indeed affected by X1Y2.
venkata
Can you tell how did you configure the GTH in GTHE1_QUAD_X1Y1 and GTHE1_QUAD_X1Y2? Whether any clocks are shared between the two links?
Anonymous
Not applicable
I am using the GTH wizard(start from scratch) from coregen.
For the both GTH quad, the corresponding gth_refclks are distributed without any other access.
The drp_clk is generated from other free-running clock.(Both of the quads are using the same drp_clk.)
Anonymous
Not applicable
For the vertex6 chip I used, there are 6 GTH quads, with 6 corresponding gth_refclks.
About the problem I mentioned, I also tried to use another quad to check.
If I configured X1Y1 with disconnected X0Y0, I didn't see the rxcodeerr of X1Y1.
It seems like that if X1Y1 is configured with disconnected X1Y2 or X1Y0, then rxcodeerr of X1Y1 shows up.
When the 2 quads belongs to the same column, their operation are not independent to each other.
Is there any solution to improve such a situation?
Thank you.
