arrow623
Problem with unused tx in a gtp tile
If I only use the RX port in a gtp tile, what should I do with the unused TX pin? Leave it floating or keep it grounding?
sushantm
Voyager
Voyager
If not using the pins you have to connect it to ground.......
sushantm
Voyager
Voyager
Where you are using GTP Transeceiver?
Please specify your application....
If you are not using then coneect it ground dont keep it floating.
arrow623
I use  the  XC5VLX30T device.
My board  uses gtp tiles to transmit data and do not need to receive data now.But  I am not sure if  receiving data function is added in the future. So,  the  MGTRXP/MGTRXN pins of the gtp MUST be tied to ground?
rcingham
In our Virtex-5 board, the unused MGTRXP/MGTRXN pins are all tied directly to ground, which seems to be the right thing.
"If it don't work in simulation, it won't work on the board."
sushantm
Voyager
Voyager
