Problem with xapp1041
Hey.
I'm using virtex 5, ML507 board.
I'm trying to test the Ethernet connection using xapp1041.
for some reason it get stuck in this loop
/* Poll until the reset is done */
    while (Reg & (XTE_RCW1_RST_MASK | XTE_TC_RST_MASK)) {
        Reg = XLlTemac_ReadIndirectReg(InstancePtr->Config.BaseAddress,
                XTE_RCW1_OFFSET);
        Reg |= XLlTemac_ReadIndirectReg(InstancePtr->Config.BaseAddress,
                XTE_TC_OFFSET);
There is a problem with the reset...
Any idea how can I solve it?
Thanks a lot.
Assaf.
Re: Problem with xapp1041
Well, I found the reason...
http://imageshack.us/photo/my-images/822/80519681.png/
This is the Indirectly Addressable TEMAC Registers.
Any idea guys about how to solve it?
Thanks a lot.
Assaf.
