Observer vermicelli
Question about byte alignment in Kintex-7 GTX transceiver
I'm developing sata3.0 protocol by using Kintex-7 GTX transceiver.
When I read the user guide(UG476, page217), I'm confused by two highlighted paragraphs in the figure below.
alignment
According to the first paragraph, I should use some logic to monitor the status of RXBYTEISALIGNED when the line rate is greater than 5Gb/s (sata3.0 uses 6Gb/s line rate). But in the second paragraphs, it says this signal is unreliable when the OOB block is used.
What should I do about this signal?
Is there any other thing about the byte alignment should I pay attention to?
Tags (3)
Re: Question about byte alignment in Kintex-7 GTX transceiver
With SATA Gen 3.0 both paragraphs are applicable. In summary, you will need to have a logic to evaluate the correctness of RXBYTEISALIGNED output.
