vishal_bits
RAM size in TCAM IP as per XAPP1151
We are planning to use TCAM IP  with depth (n) = 512 and width (m) =64  as per attached app note XAPP1151.
1. As per RAM based implemenataion section on Page 9:
   A CAM with width=m and depth=n  requires a RAM which is 2^m deep and  m-bits wide.
   If we apply this relation , the CAM uses RAM which is 2^64 words deep and 512 bits wide, which is a such huge number and hence can't be realized in FPGAs.
   Can you please help whether there is some catch in this relation ?
2. Can we use this CAM IP with BRAM implementation in ternary mode?
Vishal
