Observer david_li1984
Recovered clock of aurora 8b10b
Is it possible to receive data with the recovered clock in Aurora 8b10b design ? And if yes, how to provide the USER_CLK & SYNC_CLK of Aurora core?
Re: Recovered clock of aurora 8b10b
by default aurora takes RXREC clk. You can check in the gtp tile vhdl file
Thank you. I'll have a try.
Have a look at the Aurora example design. It provides the way to provide different inputs to the Aurora core.
Correction ! The GTP can be generated 2 ways. One the aurora core generated GTP (ignore this), this is preferred to have the updated VHDL files for aurora core and for GTPs I'm using a GTP wizard with aurora protocol where I can choose the RXRECCLK for Rx side. The later gives me updates attributes for GTPs.
 REF
http://forums.xilinx.com/t5/Connectivity/Aurora-8B-10B-core-vs-GTX-core-configed-for-Aurora/m-p/432512/highlight/true#M5487
