sunitha_vtpl
Regarding Serial Rapid IO
We are using SRIO V5.6 with XC5VFX200T-11738 configuration.We have generated IPcore by using core generator.when we open exmple design,initially some files are taken as  .ngc files.
srio_icon.ngc
srio_vio.ngc
rio_ila.ngc
phy_ila.ngc
but when we run "xtclsh create_ise_prj.tcl build project" as per UG 503,.NGC files became a .XCO files.
srio_icon.xco
srio_vio.xco
rio_ila.xco
phy_ila.xco
so my doubt is which one we should add in project .NGC or .XCO files?
Sunitha
yenigal
Refer below links which will answer your queries
http://forums.xilinx.com/t5/Connectivity/SRIO-v2-2-My-first-IP-core/td-p/415993
http://forums.xilinx.com/t5/Connectivity/how-to-use-created-ip-core-serial-rapidIO-v5-5-in-my-design/td-p/105391
Satish
sunitha_vtpl
Thanks for reply.
I have generated bitsream file.But when i am doing simulation i am not getting data on i_req_data.
first of all i am not getting data on vio_control and control0 signal is in HIGH Impedance state.
SRIO_VIO srio_vio
.Control(control0),
.CLK(lnk_clk),
.SYNC_IN(vio_display),
.SYNC_OUT(vio_control)
sunitha
