sunitha_vtpl
Regarding Serial Rapid IO
We are using SRIO 5.6 version IP core with virtex5(XC5VFX200T).Can u please give details where we can observe writting and reading data in Example design.
Sunitha
yenigal
Check the below doc
http://www.xilinx.com/Attachment/Xilinx_Answer_50166_SRIO_Debugging_Packet_Analysis_Guide_ver1.pdf
Satish
vsrunga
Please refer ds696 User (Logical Layer) Interfac section and its timing diagrams
http://www.xilinx.com/support/documentation/ip_documentation/srio_ds696.pdf
Vanitha
sunitha_vtpl
Thank you,
Is it suitable for SRIO version 5.6 ? Because it is not comes under Gen2.
Thank
Sunitha
sunitha_vtpl
We have seen Xilinx 50166 answer record.It is for Gen2.When i compared to SRIO version 5.6 some signals are missing.
There is no link_initialized signal in SRIO V5.6, so how can we know the link establishment ?.
We are getting HIGH on lnk_porterr_n .But in Answer record Figure 6 port_error is LOW. which one is correct?
We are not getting exact data on tx_data and rx_data as shown in answer record figure7. You can observe in attached file.
Please tell me whether it is correct or not?
Sunitha
