Regarding reset and resetdone signals connected in SGMII IP core
Hi all,
we are using the custom mac controller which has the GMII interface connected to SGMII ip core.
i am confused regarding the reset and resetdone signals which are input to SGMII IP when we are using the shared logic  inside the core .
we are presently connecting reset signal to 1'b0 and resetdone signal is left floating.
we cant able to able to access the pcs management registers via mdio from mac controller. we are not sure is it because of the reset signal connected to 1'b0 and resetdone floating ??
do we have to do anything to reset signal like adding the synchronizer or something ??
Re: Regarding reset and resetdone signals connected in SGMII IP core
Hi @mdakram140,
The best way is to look at the example design of SGMII core. When you generate the IP in vivado, you can right click on the xci file and click on opening IP example design.
"Don't forget to reply, kudo and accept as solution."
