Related to ethernet loopback using pcs/pma or sgmii core
          I am trying internal ethernet loopback using pcs/pma or sgmii ip core in zcu102 board, For this i selected the ip core from ip catalog in vivado, After that i have to configure this ip core according to loopback configuration.
I just wrote
assign txp = rxp;
assign txn = rxn;
in demo_tb file, what i have to do other changes and where i don't know and also i am not getting gmii_txd data.
I am attaching the screenshot of stimulus_tb.v and simulation window to point where i am facing problem.
Thank youI checked the other things also but i don't know why the data is not tranfering.I checked the other things also but i don't know why the data is not tranfering.I am getting gmii_txd signal 00 and other gmii_tx signal also.I am getting gmii_txd signal 00 and other gmii_tx signal also.please provide solution in detailed.
Re: Related to ethernet loopback using pcs/pma or sgmii core
I put the GT in the example design and then in the **_support.v file there is the line:
   .loopback_in(3'b000),
change this to:
.loopback_int(3'b010),
This will give you near end PMA loopback.   Remove the TXP and TXN assignments.  This file will be the second file in the example design hierarchy.
Thank you for your response sir , I will try it first then i will give you status of progress.
I have one more doubt sir, why gmii_txd data is not sending. In simulation it is showing 00 as you can see. So sir i need to change somewhere or not please tell the things sir.
Shyamsundar Jha
Sir I also added device specific transceiver(GT) in my example design but sir in my **_support.v file the .loopback_in(3'b000) is not there. i don't know why.
I am sharing my core tab screenshot so please find the attachment.
please guide me where i did mistake?
Thank you sir
Shyamsundar Jha
Sir I enable the GT in the example design option in the shared logic tab in our example design after that generate my example design also but sir .loopback_int(3'b000) is not showing in my **_support.v file.
if anyone have solution please guide us also.
Thank you
Shyamsundar Jha
You need to run more time to check the result in your simulation
