RoE_Framer (Radio-over-Ethernet): Simulation Issues
Hi all,
I'm trying to run the simulation of the RoE Framer v2.0.
I simply followed all the steps written on the datasheet in the Run Block Automation and Simulation sections, but it looks like that the encrypted part called roe_framer_v2_0_0_packet_gen, that packages the axis data in ethernet format, remain inactive!
While I was able to activate the axis-data-generator connected to the RoE_Framer, but only forcing TREADY='1' (that otherwise the RoE_Framer keeps it low), instead, on the RoE_Framer side, monitoring the input signals to roe_framer_v2_0_0_packet_gen, seems to me to be ok (clocks, resets, axis data, etc.) but the ethernet packet data output and the fram_ready port of the encrypted entity remain at 0.
Someone with the same trouble?
Can anyone help me?
Thanks in advance
I have same problem. Did u resolve it?
Dear ferra98,
I don't know why, but the Simulation goes on only setting devboard ZCU102, otherwise the roe_framer_v2_0_0_packet_gen remain inactive!
However I tried to implement the reference design on ZCU111 and I was able to create a link between two boards; so it seemes to be "only" a simulation issue not wellknown.
Have you tried the following AR?
https://www.xilinx.com/support/answers/72466.html
