Observer unixboy
RoE (Radio-over-Ethernet) IEEE1588 PTP test error
Hi there~ Anybody who can see the following messages on running ptp4l master. It may arise from 10g/25g AXIE network driver. Further, will be greatly appreciated with any of how to attack this crash issue.
ptp4l[61451.0709]: port 1: master sync timeout
ptp4l[61452.0291]: port 1: master tx announce timeout
Block lock has been lost : 0x00000000 : 0x00000000 : 0
ptp4l[61452.0709]: port 1: delay timeout [61452.739001]
xilinx_axienet a0020000.ethernet: Did't get FIFO rx interrupt 164626432
[61452.739982] Synchronous External Abort: synchronous external abort (0x96000210) at 0xffffff8009540024
[61452.741137] Internal error: : 96000210 [#1] PREEMPT SMP
[61452.741790] Modules linked in: xlnx_ptp_timer macb xilinx_emac zcu102(O) [61452.742642] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G O 4.14.0-xilinx-ultrascale-kmw #36
[61452.743784] Hardware name: ZynqMP ZCU102 Rev1.0 XROE (DT)
[61452.744460] task: ffffff80091c1f80 task.stack: ffffff80091b0000
[61452.745214] PC is at axienet_tx_hwtstamp+0x68/0x1d0 [xilinx_emac]
[61452.745983] LR is at axienet_tx_hwtstamp+0x48/0x1d0 [xilinx_emac]
[61452.746743] pc : [] lr : [] pstate: 600001c5 [61452.747669] sp : ffffff8008003d70 [61452.748083] x29: ffffff8008003d70 x28: ffffffc87a17b000 [61452.748749] x27: 0000000080000060 x26: ffffffc87a7fbc00 [61452.749414] x25: ffffff80085c7110 x24: 000000000000000c [61452.750079] x23: 000037e44e9502b8 x22: ffffffc87a17b700 [61452.750744] x21: ffffffc87bbd4690 x20: ffffffc87bbd4680 [61452.751409] x19: ffffff8009485e00 x18: 0000000000000010 [61452.752074] x17: 0000007f93c571c8 x16: ffffff80081abad0 [61452.752739] x15: ffffffffffffffff x14: 3631207470757272 [61452.753404] x13: 65746e6920787220 x12: 4f46494620746567 [61452.754069] x11: 207427646944203a x10: 74656e7265687465 [61452.754734] x9 : 2e30303030323030 x8 : 612074656e656978 [61452.755399] x7 : 615f786e696c6978 x6 : 00000596cd504ad3 [61452.756064] x5 : 00ffffffffffffff x4 : 000631c796720566 [61452.756729] x3 : 0000000000000018 x2 : 000000000137afb8 [61452.757394] x1 : 000000000a00417d x0 : ffffff8009540024 [61452.758060] Process swapper/0 (pid: 0, stack limit = 0xffffff80091b0000) [61452.758898] Call trace: [61452.759205] Exception stack(0xffffff8008003c30 to 0xffffff8008003d70) [61452.760012] 3c20: ffffff8009540024 000000000a00417d [61452.760993] 3c40: 000000000137afb8 0000000000000018 000631c796720566 00ffffffffffffff [61452.761975] 3c60: 00000596cd504ad3 615f786e696c6978 612074656e656978 2e30303030323030 [61452.762956] 3c80: 74656e7265687465 207427646944203a 4f46494620746567 65746e6920787220 [61452.763937] 3ca0: 3631207470757272 ffffffffffffffff ffffff80081abad0 0000007f93c571c8 [61452.764918] 3cc0: 0000000000000010 ffffff8009485e00 ffffffc87bbd4680 ffffffc87bbd4690 [61452.765899] 3ce0: ffffffc87a17b700 000037e44e9502b8 000000000000000c ffffff80085c7110 [61452.766880] 3d00: ffffffc87a7fbc00 0000000080000060 ffffffc87a17b000 ffffff8008003d70 [61452.767861] 3d20: ffffff80005cc5a8 ffffff8008003d70 ffffff80005cc5c8 00000000600001c5 [61452.768842] 3d40: ffffff8008003d70 ffffff80005cc5a8 0000008000000000 ffffffc87bbd4680 [61452.769822] 3d60: ffffff8008003d70 ffffff80005cc5c8 [61452.770441] [] axienet_tx_hwtstamp+0x68/0x1d0 [xilinx_emac] [61452.771341] [] axienet_start_xmit_done+0x118/0x1c0 [xilinx_emac] [61452.772295] [] axienet_tx_irq+0x148/0x1b0 [xilinx_emac] [61452.773148] [] __handle_irq_event_percpu+0x5c/0x148 [61452.773954] [] handle_irq_event_percpu+0x1c/0x58 [61452.774727] [] handle_irq_event+0x48/0x78 [61452.775426] [] handle_fasteoi_irq+0xb8/0x1a8
Re: RoE (Radio-over-Ethernet) IEEE1588 PTP test error
Hi @unixboy
Can you please confirm on the setup and design which you are running. Is it the demo of RoE?
I beleive there is no link established for Core when you got this error.
Observer unixboy
Hi kgadde.
Thanks for your comment and I am unfortunately not remembering where I got the design, but I posted the screenshot of design shown through Vivado 2019.1. roe_design.png
It might be questionable how it can make you catch up what version(design) I am now using, but this design could be downloaded from Xilinx site by free without license agreement. It could be a sort of demonstration matter, but it was full enough to catch up how well IEEE1588 PTP 1 PPS tracing is achievable through Xilinx solution.
Linux drivers and DTS I tested is all originated from "xroe_framer_demo_2018_3.bsp" file obtainable from the Xilinx site as well. Yes, the error came from the case when we turned off PTP slave ZCU102 board. We used 2 ZCU102 board for either master or slave, and when we turned off the slave. The error happens in the master ZCU102 board. Do you guarantee the reliability of 10g/25g AXIe Ethernet driver even with such a crash?
When we use the both ZCU102 boards two masters (not SynE evironment), this error would not happen. When I switched to "two masters mode" only PTP protocol contributes to 1 PPS clock synchronization with its own built-in algorithm. Two ZCU102 boards might use their own TPU clocks.
@unixboy
I can reproduce this issue in 2019.2 build. It only errors out with master command.
If you try with ptp4l -m -A -i eth0 -f /usr/bin/xroe-ptp4lsyncE.cfg -s, it should work fine.
We have reported this issue, and ethernet driver team is still investigating this.
2018.3 build shouldn't have problem.
Observer unixboy
Thanks Xud for your comment.
Wasn't 2019.1 recommended for RoE job more than 2018.3 by Xilinx? Which one is more useful when we work with RFSoC not MPSoC ?
@unixboy
The official released RoE application is 2018.3 : https://github.com/Xilinx/wireless-apps
 We don't have plan to release 2019.1, there is plan for 2019.2 though
@unixboy
I have tested 2019.1 build on ZCU102 board, it works fine.
My 2019.2 issue was related to following fix in driver. When I revert the fix, it doesn't crash anymore.
https://github.com/Xilinx/linux-xlnx/commit/8f09da4c85b76c3616723f94660ebe4408c517c9#diff-79b4c5af77f83bc2aab258db04000161
Can you PM your email address please? I will work with you offline, so you can transfer your petalinux project to me.
I will have a close look at your design.
