Participant yurivn
RoE (Radio over Ethernet) with data in frequency domain
Hi everyone,
I implemented RoE project with data in time domain on ZCU102 and got successful. But when using Frequency domain mode on RoE IP Core setting, I couldn't see any packet out RoE (after "frame" IQ samples from antenna) (data was captured by ILA).
So anyone have an experience about this case, please let help me to solve.
Thank you,
回复: RoE (Radio over Ethernet) with data in frequency domain
What's the version? RoE is a new IP core. Please use the latest version tool.
Have you run simulation before? Does it work in simulation?
We also provide an example design with the simulation. You can try the example by following this AR72466
https://www.xilinx.com/support/answers/72466.html
Participant yurivn
I'm using Vivado 2018.3.
So, today I re-generate block diagram with configure Frequency domain of RoE Framer first, it works.
I think may be there is a lot of different things between block diagram was generated with RoE Framer time domain configuration and RoE Framer frequency domain configuration.
