RocketIO GTP Simulation Problem
I am trying to use RocketIO GTP Wizard v2.1, but right after I finish customizing the IP Core, I get such an error message:
ERROR:ProjectMgmt:387 - TOE: ITclInterp::ExecuteCmd gave Tcl result 'invalid command name "com.xilinx.coreutil.exception.SWinconsistency:"'.
Tcl_ErrnoId: ENOENT
Tcl_ErrnoMsg: no such file or directory
_cmd: ::xilinx::Dpm::dpm_chCreateNewSource $piThisInterface
errorInfo: invalid command name "com.xilinx.coreutil.exception.SWinconsistency:"
    while executing
"com.xilinx.coreutil.exception.SWinconsistency: "
    (file "D:/desktop/tmp/sil1/kor_xmdf.tcl" line 1)
    invoked from within
"source [ lindex $xmodPaths 0 ]"
    (procedure "::utilities_xmdf::xmdfLoadXmod" line 50)
    invoked from within
"::utilities_xmdf::xmdfLoadXmod $moduleName 0 $filesDir "
    (procedure "::utilities_xmdf::xmdfGetOutputList" line 13)
    invoked from within
"::utilities_xmdf::xmdfGetOutputList $sModule $sFilesDir _XmdfOutputList"
    (procedure "dpm_coregenGetOutputList" line 23)
    invoked from within
"dpm_coregenGetOutputList $sCoreModuleName $iProject $sCoreDir _genList"
    (procedure "dpm_coregenCreateCore" line 50)
    invoked from within
"$_sCreate $_filePath $_iNewSourceComp _OutputFileList"
    (procedure "::xilinx::Dpm::dpm_chCreateNewSource" line 61)
    invoked from within
"::xilinx::Dpm::dpm_chCreateNewSource $piThisInterface"
I found some suggestions to overcome this problem (such as updating the IP, giving the same name to both project and core, etc.) but none worked for me. There are some files created under the core folder, but all vhd files are filled with the following message:
 Sim Parameter 'GTP0_USE_PORT_TXELECIDLE' not found
Any suggestions?
Thank you
@sinan.taylan Looks like crash, What ISE version are you using? Can you try with 14.7 if using older one
-Pratham
Which device are you targeting
xc5vlx50t
Firstly I used 12.1 after 14.2 and 14.4. I have not any solution about this topic
If you are enabling TXELECIDLE port while generating, please try to generate without this signal enabled.
if you find .xco file in the generated files, please share it.
