mtnli89
SFP+ and kintex7
I want to run SFP+ in my FPGA (kintex7). actually I used 10 Gigabit Ethernet Subsystem v3.1 IP core and it would seem that everything runs ok. Now, I have a question. Can I implement tcp/ip or udp/ip both? there would not be any problem by using these two protocols?
nanz
Hi  @mtnli89 ,
Yes, you can. But Xilinx does not provide 10G baremetal driver if you are looking to implement it in standalone. In Linux, it's supported:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842485/Linux+AXI+Ethernet+driver
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
