[SGMII : Zynq ] : Phy not getting initialized when read through MDIO.
Hi all,
I am using Zynq FPGA, I have added AXI_ethernet in SGMII mode (Vivado 2014.1).
I m trying to read the Phy registers through MDIO.
The phy is not getting initialized.
the values are not as expected. plz help..
thanks.
yenigal
Can you give more details regarding what do you mean by values are not as expected.
Are you able to read and write to the registers using MDIO?
Satish
