wa78op
SRIO IP gen2 usage problem
Hi,all
I am using the SRIO IP gen2 core 4X 6.25Gbps in the FPGA KU035-FBVA676-1. Now I set the loopback to the 3'b010 self-loopback test. I use the NWRITE and SWRITE transfer modes and find that after the data is normally transmitted and received for about 1 hour. The FPGA debug window shows that only the TX side data is sent on the SRIO interface, but no data is received back on the RX side. I grabbed the trigger for the signal :core_received_pna, core_received_pr, core_sent_pna, core_sent_pr not set.I don't know what caused this phenomenon.
karnanl
Hello Yan @wa78op
I am sure that this is the cause.
--BTW, I am not familiar with SRIO IP.
   So, I cannot give you a comment whether sudden-stopped after one-hour is expected (instead of 2-8 hours as mentioned by the screenshot.) or not.
   But, most of Xilinx Licensed-IPs have this kind of mechanism that is automatically enabled when using evaluation license.
For license related matter, could you please contact Xilinx Distributor FAE/Sales  ?
Thanks & regards
Leo
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
Versal Example Designs : LINK
karnanl
Hello @wa78op
I am not sure if i understand your question correctly.
So, you have found that your SRIO IP is suddenly stopped working , after normally working for about 1 hour.
Is my understanding correct ?
If yes, could you please check if you have SRIO IP license available on your PC/Vivado ?
Thanks & regards
Leo
wa78op
Hello,Leo
What you understand is correct. After SRIO sends data and receives data for about 1 hour, it suddenly cannot receive data.
As for the  SRIO IP license I use, it is an evaluation version applied from Xilinx. The VIVADO SRIO IP interface displays "Hardware_Evaluation IP license available".
Thank you,
Yan
wa78op
Hi Leo,
I revisited Xilinx's instructions on the use of the Hardware Evaluation license, and the SRIO IP license I used is also a Hardware Evaluation license. Should this be the cause?
Yan
karnanl
Hello Yan @wa78op
Thanks & regards
Leo
wa78op
Thank you very much for your answer to this question.
