SRIO connect to AXI-Lite interface
Hi! Tools - Vivado 2013.3. SRIO Gen.2 (v.3.0). How to connect SRIO core to the Microblaze processor. AXI-Lite interface is available (SRIO core) but there is no clock signal (s_axi_aclk) ?
Re: SRIO connect to AXI-Lite interface
The log_clk_out will be used for the Axi lite interconnect Master interface axi clock.
Have a look at the attached snapshot showing the connections from the Microblaze to an interconnect and to the axi lite interface of the SRIO core and the clock connections.
Satish
Satish
Hi! Thanks for the quick reply. Another issue - how to connect s_axi_maintr_rst?  (// Reset for maintr interface, on LOG clk domain). Thanks in advance.
