sunitha_vtpl
SRIO interfacing
we are using srioV5.6 IP core  with XC5VSX50T(ML506).As mentioned in userguide UG503, i understoode the path for Nwrite and Nread..
we are connecting loopback. when i observe the chipscope results, data on phy_tlnk_d and phy_rlnk_d are same but TX_DATA and RX_DATA  (these are input and outputs of rio_buffer)  are not same. you can observe the chipscope results in attached file.
so please tell me which signal i have to change to get  TX_DATA ,on RX_DATA  signal?
sunitha
sunitha_vtpl
sunitha
