Visitor rbanks
Set JESD204 v7.1 samples per frame
Is there a way to set the samples per frame in the JESD204 v7.1 IP block besides using the axi bus to write the register?
rbanks
Re: Set JESD204 v7.1 samples per frame
No there is no other way than the AXI lite register writes to configure the Samples per frame.
Satish
Satish
