bfrazier_arete
Status of PS-GTR and 1000BASE-X in Zynq Ultrascale+?
What is the current status of 1000BASE-X support using the PS-GTR?  It is called out in the TRM and other documentation, however, posts in the forum from 2018 state that the support for GEM through PS-GTR is only SGMII.  Has there been any update to fully support 1000BASE-X?
We would like to connect two Zynq Ultrascale+ through a network connection and would rather do it via a point-to-point like utilizing the PS-GTR rather than instantiating the PCS/PMA core in the PL and using the GTH section of the PL.
stephenm
Yes, you can use fixed link phy in the device tree. You will need to disable AN.
we have the same configuration i.e. ZynqMP/PS-GTR to SFP+/1000base-X and we use Vivado 2019.1. Could you please provide the device tree snippet that needs to be added?
many thanks
Paschalis
stephenm
spiwoks
Hi Stephenm,
I am Ralf Spiwoks, working with Paschalis. We did add the snippet to the device tree as follows:
&gem2 {
   fixed-link {
      speed = <1000>;
      full-duplex;
Then we rebooted the ZynqMP and got the messages as in the print out added below, see xxx.log.
After boot we used ethtool and ifconfig to configure the eth2 interface, see yyy.log.
Unfortunately, the Ethernet interface does not get correctly connected. Ping does not
work (see yyy.log). The other end (a regular Linux PC with an interface we had tested
beforehand to work correctly) does not see
any light:
[root@pcphl1ct07 mpsoc]# ethtool p4p2
Settings for p4p2:
Link detected: no
Could you please advise us on what other tests to do? Any hint with the issue is
highly appreciated.
Thanks a lot for your help.
Cheers,
                       Ralf.
spiwoks
Hi all,
Here are some updates:
1) The "ethtool" seems to be completely unconnected to the hardware. Whenever we disable the
    autonegotiation using "eth -s eth2 speed 1000 duplex full autoneg off", we see it correctly announced
    by "ethtool eth2". However, it is still enabled as we can see from the GEM PCS control register at
    0xFF0D0200.
2) With my colleagues, including S. Haas and P. Vichoudis, we managed to enable the ethernet finally
    by running the following sequence:
    ifconfig eth2 down
    ifconfig eth2 192.168.2.10
    poke 0xff0d0200 0x8140     # disable GEM2 autonegation and soft reset
    poke 0xff0d0200 0x0140     # desassert soft reset
    testGPIO -n 23 -d 1 -v 1       # assert hard reset of the SFP
    sleep 1
    testGPIO -n 23 -d 1 -v 0       # deassert hard reset of the SFP
    sleep 3
    After that sequence the ethernet link comes up and is functional, i.e. we can ping the other end,
    and be pinged by the other end.
For us, this is acceptable as a solution of how to get the ethernet link running, although we would
have thought that the disabling of the autoneg and the (soft) resetting of the SFP should have been
done in the kernel by the corresponding PHY driver ....
Cheers,
                        Ralf.
just a small clarification concerning the previous message - it is the SFP "TXDIS" control signal that is referred-to as "hard reset of the SFP".
Cheers
Paschalis
andrei.tunea
Hi Paschalis,
can you please share how you connected the rest of the SFP IOs to the Zynq? The PS-GTR lanes for receive and transmit data are obvious, but the I2C and other status pins interest me.
andrei
spiwoks
Hi Andrei,
My colleague, Paschalis Vichoudis, sent me the following picture, which should explain how he solved the problem.
Cheers,
Ralf.
