nansi
TEMAC evaluation license limitations
Hi all,
Is the evaluation license of TEMAC IP limited to use/run only one of this IP at a time?
Actually, I am evaluating TEMAC IP (through AXI 1G/2.5G Ethernet) on a Zynq platform. And I have a design with two AXI 1G/2.5G Ethernets in the PL part. Everything works fine on axi_ethernet_0, but not on axi_ethernet_1. Before investigating further, I am wondering if this is due to a limitation with the evaluation license.
Thanks in advance for replying!
nanz
Hi @nansi ,
No there is no such limitation. This sounds like a design related issue. Can you please confirm if ethernet_1 is working alone first?
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
nanz
Hi @nansi ,
nansi
Hi @nanz
Thank you for your reply. Actually it was a software issue. We did a quick hack (see attached file) for it to work. We will investigate this more later.
On my side, we can consider this ticket as done.
Kind regards!
